I'm new to electronics (so bear with me
) and I'm trying to build a simple solar recharger for a battery or a series of batteries that will power couple of LEDs.
I've looked around the internet and I found some resources to get me started, such as AA Battery Solar Charger and this forum.
I currently have a solar panel hooked up to a AA 1.5V rechargable 1800 mAh NiMH battery (output rated 1.2V). I placed a diode in between. I tried to recharge a battery yesterday, and it appears to have worked.
There's some stuff I can't figure out though. Here are my questions:
1. How exactly does the charging work? I searched around for this, but I can't find a simple conclusive explanation for this. Does the voltage coming from the solar panel have to be larger than the voltage of the battery for it to actually charge?
For instance, do I need to match the solar panel's output to the battery being charged? I know it shouldn't be (much) higher, but can it be lower? I currently had a panel hooked up that put out a maximum of 2V in bright full sunlight to a 1.5V AA battery. Could I hook up a 0.5V panel to the same battery and expect it to work? Or would this just charge the battery to 0.5V and then stop charging?
2. I read about solar charging batteries and I understand that the type of charging I'm using isn't exactly ideal, but that it is safe (if not good for the battery though). I'm looking to charge AA batteries or 9v batteries. What are your thoughts on this? Should I use NiCd batteries or NiMH ones?
3. I don't know the exact type of the diode. I asked for a Schottky diode in the electronics store. The receipt shows "BAT85 Diode" which is also printed on the diode itself. I was told I could find the exact specifications on Velleman nv. On that site the closest match is **broken link removed** I believe. However, the model number doesn't match I believe and a Google search yields this: BAT85 Datasheet pdf - Schottky Diodes - General Semiconductor.
I do believe the diode is ok, but I'd like to have the exact specifications. The datasheets from the second URL says "continuous reverse voltage 30 V, continuous forward current 200mA".
Does this type sound ok? Which source should I consider as correct?
Would this limit the output of a 0.5V 800mA (because of the "continuous forward current 200mA")?
4. This question is sort of a catchall and ties into question 1. I have access the following components: the diode I was talking about in question 3, the following solar panels: **broken link removed**, and various types of batteries.
Let's say I wanted to charge a pack of 2 1.5V 1800mAh AA batteries. What kind of setup would you build?
The setup needs to fit into a confined space, so I'm afraid it's not as easy as attaching as many panels as I like.
5. Could I change the AA batteries for C or D type batteries? Would this impact the circuit any way other than increased power capacity from the batteries?
6. I read on some battery I had lying around (type C if I remember correctly) that it is "protected against overcharging". Is there any truth to such claims?
I appreciate any and all feedback!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
