AtomSoft
Ok i have a potential issue on my hands. I have a 24 SIGNALS cut into groups of 3.
Lets call them A, B , C... which have 8 signals each
I want to be able to use each separately at one point then have the option to combine them... so my circuit can be
A0 ---------- ITS OWN LINE
A1 ---------- ITS OWN LINE
A6 ---------- ITS OWN LINE
A7 ---------- ITS OWN LINE
B0 ---------- ITS OWN LINE
B1 ---------- ITS OWN LINE
B6 ---------- ITS OWN LINE
B7 ---------- ITS OWN LINE
C0 ---------- ITS OWN LINE
C1 ---------- ITS OWN LINE
C6 ---------- ITS OWN LINE
C7 ---------- ITS OWN LINE
And either i use a solder jumper to connect each like:
A0 - A7 = 1 SIGNAL LINE
B0 - B7 = 1 SIGNAL LINE
C0 - C7 = 1 SIGNAL LINE
to make only 3 signal lines...
But then if i want to have all 24 lines separate again i would have to desolder them all.. how can i do this digitally ? The max voltage on each line will be 3.3v i doubt it will use much current at all. Its just normal signal pins.
So basically i want to be able to switch from having 24 DATA LINES to 3 DATA LINES and back and forth... without having to solder and desolder or having BULKY HEADERS...
Any ideas? perhaps like some digital switch i can use to connect them?...
Thanks in advance![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance
