You solder withe a soldering iron, not pry, cut, or melt other things, doing so will shorten the life.
Get quality.
Don't use acid or abrasives.
Get an adjustable one and turn down the heat.
Always make sure there is a lot of solder on the tip, only wipe it off just before you solder something. Then reapply again before putting the iron back down.
Then at what temp should I regulate it when it's not in use?
leave it unpluged and in the box out the wayI've recently disposed my fifth soldering iron .. any tips to preserve the sixth one?![]()
