I bought this: https://www.amazon.com/Parts-Expres..._1?s=industrial&ie=UTF8&qid=1403923606&sr=1-1
On the back of the packaging it says: "Clean before use. To clean, remove the tip, clean the body, internally. Once the body and tip are clean, replace the tip." It says the same thing on the little instruction sheet inside. Why clean it before use? Does it mean each use? How do you clean the body? It said nothing about cleaning the tip, but then it said that once the body and tip were clean to replace the tip. I'm assuming "replace the tip" means to put it back on, not buy another tip.
Steren has some retards working for them...
