nuttaphong191
Ok, I’ve made my first DIY PCB, I’m trying to solder Leds into the holes and I’m a complete newbe, I got a Weller WES51, and I’m using a 1/32 0.8 mm tip. I set it to 65 watts it goes from 35-85.
Now I put the tip on the pad next to the led and then tough the solder to the led pin.
When I do manage to get the solder to melt it does not flow right.
It just globs around the led pin, I thought the pad & pin were susposed to suck the solder into the pad area kinda tight so I would have a clean joint, but that don’t work.
QUESTION:
What do I need to do? What am I doing wrong ? I tried putting some solder on the
Iron tip to “Tin” it, but there is no difference.
QUESTION:
