scwhiteley
Hello! Quick soldering iron question here.
First off, I have a 30 Watt radio shack soldering iron that inexplicably stopped working after about two weeks of use... I really wish I would have hung on to that receipt. Is this common? Is there an easy fix for this?
Anyhow, that was long ago, and I've since been using a 45 Watt Craftsman soldering iron. It works well, but I seem to go through tips pretty quickly. They only seem to last a week or so before I need to replace them, which is unfortunate, because getting replacement tips from Sears is like pulling teeth. Is 45 watts too hot or is it normal to burn through tips this quickly?
At this point, I'm considering investing in a new soldering iron, and I'm open to suggestions. All of the soldering I do is on electronics, and I'm not one hundred percent sure what wattage of iron I should be using.
Thanks again,
Chad
Thanks again,
Chad
