Whovian
I just started to learn to solder and so far I've built an LED blinker from scratch using a 555 timer and I've built a small FM transmitter from a kit. I've also started to learn how to desolder using desoldering braid. I was wondering which kind of components I need to worry about when it comes to heat? I know that some parts can be damaged if you leave the iron on them too long. I was just wondering which common types of components I need to worry about with the heat issue? I should probably add that I'm using a 15 watt soldering iron.
Thanks for any help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks for any help
