monkeytree
has any body got any tips on how to solder surface mount resistors there size is Length 2mm,width 1mm, height 0.5mm
monkeytree said:has any body got any tips on how to solder surface mount resistors there size is Length 2mm,width 1mm, height 0.5mm
monkeytree said:all i did was have a closer look at them and lost three![]()
how big is the chance that they will be engulfed by the solder?
Nigel Goodwin said:You have to use very small amounts of solder, then there's no chance.
bmcculla said:I find that with solder paste I have a terrible time with the problem bonxer mentioned - the solder doesn't stick on one side ant the component sticks strait up - even when I use hot air. The iron and tweezers is much faster and more reliable for me.
