; // setup a 1000 usec PWM period with PR2 = 249 and prescaler
; // 4:1 (4 MHz clock) or 16:1 (16-MHz clock) and use 25 of
; // these shorter PWM "frames" to make the much longer 25-msec
; // period. Resolution is 1-usec.
; int width = 1500; // pulse width, 0..24999 (usecs)
; int pulse = 0; // ISR work variable
; int frame = 1; // frame number 1..25
; void ISR()
; { PIR1bits.TMR2IF = 0; // clear Timer 2 interrupt flag
; frame--; // decrement frame number
; if (frame == 0) // if end of 25 msec period
; { frame = 25; // reset for new 25 msec period
; pulse = width; // reset 'pulse' work variable
; if ((pulse > 1000) // if pulse > 1000 usecs
; { CCPR1L = 250; // do a 100% duty cycle frame
; CCP1CONbits.CCP1Y = 0; //
; CCP1CONbits.CCP1X = 0; //
; pulse -= 1000; // subtract 1000 usecs
; else
; { CCP1CONbits.CCP1Y = (pulse & 1);
; CCP1CONbits.CCP1X = (pulse & 2);
; CCPR1L = (pulse >> 2); // 0..249 (0..999 usecs)
; pulse = 0; // remaining frames are 0%
It's actually linking together 25 higher frequency PWM "frames" to produce the much lower 40-Hz PWM signal you require.Is that basically outputting 1 ms bits of a hi freq. pwm?
Won't that still induce higher impedance due to coil inductance?
