northbound
I curently building a solid state driver to be used on a boat autopilot to drive a 12 volt DC reversing motor (30 amps).To achieve, I use four DC output solid state relays rated 40 amps, 100 VDC.Since the electric motor will be energized with polarities which alternate according to the vessel's heading, I am concerned about the precautions to be taken to protect the solid state relay from transcient voltage at turn off . The SSR data sheet suggest to use a reversed-biased rectifier diode in series with a zener diode (opposite direction) or a varistor (MOV) to be installed accross the output terminals of the SSR. Does someone could help me determine the value of using diodes (voltage and amperage) or suggest me the best system to be used ?
