electroRF
Hi Guys,
I wrote a mechanism (which I previously discussed here), which does the follow:
When Calling funcA or funcB, I set Stack Pointer to the first Address of GlobalStackBuffer (that is a global array with enough space to handle local variables).
My bug is that I did not notice the following situation:
Func A defines a local Array which since its a local array it's defined inside GlobalStackBuffer.
Then funcA calls funcB and sends the array's address to funcB as an argument----> As a result, funcB will overrun the array's address, because the Stack of funcB will start from the same GlobalStackBuffer.
How would you solve this bug, while keeping the mechanism in which the Stack Pointer of funcA and funcB use GlobalStackBuffer space?
An important thing to note is that there's no return from funcB, since at the end of funcB the program enters infinite loop.
I thought to solve it by just before funcA calls funcB, it'd store buff's values inside the first address of GlobalStackBuffer, and have SP of funcB to start from GlobalStackBuffer + sizeof(buff)
But you always have better solutions![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you very much.
C:
void funcA(short int title, short int, size, short int *buff)
short int buff[size+1]; //Our compiler allows defining variable-size Array, which will be stored in the stack
//.... initializing buff
funcB(title, size+1, buff); //buff address is sent to funcB
void funcB(short int title, short int, size, short int *buff)
while (1);
