i want to make a robot which detect walls and chooses the correct path.
robot's micro controller and complier will be Atmega32L , codevision.
four IR sensor will be wall detectors.
here is the circuit of IR sensor
my problems:
1.the range of IR sensor is too short it can only detect thing closer than 20 cm (if i use 5mm photodiode LED receiver )
how can i increase the range up to 1Meter
or its better to use ultrasonic sensor as distance meter???
(if yes could you tell me how can i use this sensor with atmega 32 and can i use 2 sensors on one atmega 32??)
2.what is the best xtal's frequence for atmega32 in order to run the program quickly??
3.how can i drive 2 motors, control the speed of them and change the rotation orientation easily??(lm298??? if yes could you learn me how?)
sorry for my bad english
thanks for your guidance
my problems:
