something about interrupt
johnson
dear all,
I have some problem regarding using an interrupt. When an external interrupt occurs, I want the program counter to jump to the specific label instead of continue from the code that interrupt occured. Any suggestion?
I wrote this in pic basic but it does not seem to be correct:
disable
isr:
    if (mode<=maxmode) then
        mode=mode+1
        intcon.1=0
        pause 50
        goto main
    endif
enable
the code shows that whenever interrupt occur, after operation the program should jump to main instead of continue the code.
You are probably having stack problems. Are you using the PIC BASIC PRO from microengineering labs? Are you using the ON INTERRUPT command? Is the code for the interrupt handler?... post some more of your code
Ivancho
yes, i am using using pic basic pro:> structure my code structure looks like follow:
option_reg =0
intcon = $90
on interrupt goto isr
mode var byte
maxmode var byte
main:
goto main
disable
isr:
        mode=mode+1
        intcon.1=0
        pause 50
        goto main
    endif
enable
thanks in advance:>
cheers
What version of PIC BASIC PRO are you using?... you are missing a RESUME on your program... The interrupt handler doesn't like to have jumps within the handler.... something to do with the stack, it will not be able to record and know where it was last at.
I would change your code like this.... (change the Goto Main... to ... RESUME Main), and change the DISABLE so that when the interrput jumps to the label you don't retrigger the interrupt if there was another interrupt signal.
option_reg =0
intcon = $90
mode var byte
maxmode var byte
main:
goto main
isr:
disable
        mode=mode+1
        intcon.1=0
        pause 50
        RESUME main 'Resumes at Main if above condition is true
    endif
     RESUME   'returns to where it was interrupted at since if conditions id false
enable
Make sure you understand that using the PIC BASIC ON INTERRUPT command will make your code quite long. When compiling the ON INTERRUPT will put a short subroutine after EACH STATEMENT ON YOUR PROGRAM that checks the state of the Global Interrupt Enable bit. So if you are doig a PAUSE 10000 on your main program, and a interrupt happens, the code will not be interrupted until the PAUSE 10000 is over with. But most of the time you doint' have such a delay so interrupts happen much faster. Sitll you have to understand that problem does exist.
If you can't live with that then you are going to have to make a interrupt handler with assembly within the BASIC program.
Ivancho
An interrupt routine must always be ended with a retfie the normal way. Otherwise a new interrupt can't occur (on a pic) or you will have stack overflow when it does happen enough times (other platform).
An interrupt routine and the main program should be seen as two independent programs, you cannot just jump from an interrupt routine back into normal code. what you can do is set a flag in your interrupt code, and then somewhere in the main program check that flag and act acordingly.
