pradeep_vesker20008
how use & make a sonar radar.diff. b/w sonar,ir senser &what ir senser.
life is struggle so always b+![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
life is struggle so always b+![]()
i know about infrared sensor, i don,t know ir is short form of infrared.
i make a sonar for long range because i found some prototype circuit of sonar but it range is very low so i make a sonar which range is minimum 50 meter. u help me find this.
Is this in air or in water? 50 meters is a long way for sonar in air, since ultrasonic frequencies are absorbed fairly well by air. You will need a powerful driver and a sensitive receiver.
Can you answer the questions that I asked? They will help us to help you.
Torben
Morning Torben,
Another problem which I expect you are aware of is deflection of beam by air draughts.
I agree about the 50mtr problems.
We used to test our 33KHz and 200KHz depth sounder systems in air,
about 10 to 15mtrs was the limit at the high powers we were using.
If someone opened a window the draught would deflect the beam.
Hello,
It sound interesting using sonar in water is much better than using it in air as a medium. What about different liquids, I mean such as oil or different liquids with no transparency does it effect sonar range. I believe that, it should effect it slighty because sonar work using sound. Am i right?
Can you recommend sonar to be used underwater or other liquid that can range 100m?
