Hey guys,
I have a circuit that I have built using led's and I have run into a problem.
I have a 555 timer on the circuit which will turn all the led's on a once for
about 5 seconds. After the circuit finishes with this time delay I want it
to switch over to a contoller circuit that will make the led's go through a
chaser sequence.
In "layman's terms" when the power is supplied (12v dc) all the led's will
shine for 5 seconds but after this function is completed I want to use a
spdt relay to "switch" the led's to illuminate in a different fashion.
I know that there are easier ways to do this with pic's but I need to know
how to utilize this with the spdt relay (if that is even necessary).
That's kind of what I need you guys for. I have worked out everything but
this detail. I am a major "ametuer" (sp) hobbyist and know enough to tinker
but I had rememberd someone suggesting using a spdt relay but I forgot
how to wire it in.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
and THANKS!!!!!!!
chaser sequence.
how to wire it in.
and THANKS!!!!!!!
