A 22 ohm resistor in series with an 8 ohm speaker reduces the max power to the speaker to only 30%.mneary said:First try a 22 ohm resistor in series with the speaker. It probably won't work to your satisfaction but it's simple enough, worth a try.
I considered that, but this is after all a PC mounted speaker, and the purpose is unknown.resistor in series with the speaker ruins the damping
Scarr said:Dean, are you saying that this IC might already be able to drive a PCB mounted speaker?
