I am using the PIC16F877A uC.
I wanted to do sampling at a fixed rate.
The special event trigger simplifies matters since, when TMR1 count matches CCPR2, A/D conversion should automatically begin according to the data sheet.
But in my program that is not happening. :cry: I have switched on the A/D module.
I wanted to know do we have to manually start the A/D conversion by setting the GO/nDONE in ADCON0
Here's the relevant code:
movlw B'00000000' ;Timer1 set for internal clock with 1:1 prescale value & ensured that it is off
movwf T1CON
clrf TMR1H ;clear Timer1H & Timer1L registers
clrf TMR1L
clrf CCPR2H
movlw B'00001011' ;Special event trigger mode for ADC sampling at fixed rate
movwf CCP2CON
Pulse1 ;To ensure interrupts are disabled
bcf INTCON,GIE
btfsc INTCON,GIE
goto Pulse1
movlw H'9E' ;ADRESL - Low byte storage of A/D result
movwf FSR
movlw B'10000001' ;Fosc/32 for 1.6us T-AD, AN0 as i/p channel, A/D module made on
movwf ADCON0
movlw H'C8' ;40uS sampling time
movwf CCPR2L
bsf T1CON,TMR1ON
REPEAT
bcf PIR2,0 ;Clear CCP2IF flag
movf INDF,W
movwf PORTB ;portB o/ps 8 LSBs
movf ADRESH,W
movwf PORTD ;PortD's 2 LSBs contain 2 MSB's of digital outputs
BACK
btfss PIR2,0 ;Wait for CCP2IF flag to be set.
goto BACK
NOTOVER
btfsc ADCON0,2
goto NOTOVER ;Polls to see whether conversion over
goto REPEAT
Kindly check & let me know the flaw in the program.
Thanks in advance...
movwf T1CON
clrf TMR1L
clrf CCPR2H
movwf CCP2CON
bcf INTCON,GIE
btfsc INTCON,GIE
goto Pulse1
movwf FSR
movwf ADCON0
movwf CCPR2L
bsf T1CON,TMR1ON
REPEAT
movf INDF,W
movf ADRESH,W
BACK
goto BACK
NOTOVER
btfsc ADCON0,2
goto REPEAT
