Hi there. I am building a prototype device, and it requires a timing circuit that has to work in a very specific way (I've searched high and low for a ready-made solution, to no avail). I can build a circuit from schematic no problem, but I have no idea about theory when it comes to anything more complicated than resistors and diodes.
I was wondering if one of you guys would be willing to help me out..
Here's the requirements..
Must operate on 2-3vdc (2 AA or C batteries)
Must be very low drain, looking to be able to run for months without changing batteries
Must be able to drive a small, low current 2-3vdc motor (off same batteries) without a relay
Depending on a switch setting, must run motor for 1 or 2 seconds per actuation
Depending on a switch setting, must provide one actuation every 6,8, or 12 hours (not time critical, just two, three, or four times per day)
Must have a manual actuation switch that does not reset or interrupt timer (ie: if manual button is pressed 5 hours into a 6 hour cycle, it will still actuate automatically 1 hour later).
Pretty simple, right? Here's the kicker: Must have an ambient light rejecting infrared proximity sensor that PAUSES (not resets) the cycle when an object is detected. It must keep the timer paused for a minimum of 5 minutes after the object is no longer detected. After the 5 minute delay, the cycle must continue where it left off. Ambient light rejection is critical, as the detector will be exposed to varying levels of ambient light in normal operation.
The proximity sensor also needs to be as small as possible (no larger than a dime), and must be able to be remotely mounted - say, no more than 3 cable feet off the main board.
So.. Any generous person want to tackle this?
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Much thanks in advance!
Matt
Matt
