For my magnetic compass, it has the following pin in addition to the MOSI, MISO, SCK, and SS pins for the SPI interface:
SYNCH PIN:
"The SYNC line is not needed except in cases where the V2Xe gets out of
synchronization with the host; a rising edge on the VX2e SYNC line will reset
the V2Xe’s SPI and communication buffers. Synchronization problems mostly
occur during power up when I/O ports and hardware are being initialized. This
may cause glitches in the clock line and might be interpreted by the V2Xe as
clock cycles. The SYNC line is totally asynchronous with respect to the SPI so
proper care in its implementation is highly recommended."
What exactly is this loss of synchorinization on the SPI line? I've never seen this line on any other SPI interface. I'm not sure why I haven't see this if it is something (loss of synch) that could happen.
SYNCH PIN:
