I have an lifetime ban on AAC for sticking up for you. I won't lose any sleep thoughIf it is a SMPS, live with it, or take the damn thing out and shoot it with a gun.
Not SMPS. Series regulator supply.If it is a SMPS, live with it, or take the damn thing out and shoot it with a gun.
Without load and with load, the change is marginal only.Is the power supply connected to a project?
Post the circuit. Likely missing capacitors or bad capacitor.Not SMPS. Series regulator supply.
Do you mean that that much level is acceptable for a series regulator? Is there no way to eliminate that?Looking at the scope settings it's only 20mV p-p anyway
Two choices are to modify/fix the circuit (if you have its schematic) or add an LC filter on the output.Do you mean that that much level is acceptable for a series regulator? Is there no way to eliminate that?
5mV peak-to-peak is a spec quote from many half decent lab power supplies. Trying 100nF capacitors on the rails. Try an LC line filter.Do you mean that that much level is acceptable for a series regulator? Is there no way to eliminate that?
