A symmetric 50% duty cycle square wave is made up of a bunch of sine waves. The frequency of the square wave is the frqeuency of the lowest frqeuency sine wave (the fundamental frequency). From there, the sine waves are odd harmonics of the fundamental. So they are multiples of 3, 5, 7, 9, etc of the fundamental. Filter these high frequencies out and you have just the sinewave.I am trying to design a motor driver for a Robot Arm. I need to convert a square wave to a sine wave. My square wave has a peak-to-peak voltage of 80V and a current of 2.5A. What circuit must i use to be able to accommodate this large voltage and current? Thank You.
Sine wave inverters are among the most difficult to build and there's a crapload of work that goes into making them. From the sounds of it you need about 3 more years of school before you even have a hope of attempting one. Frankly, I don't think the OP is going to be able to build one either. It's almost the kind of thing that if you have to bluntly ask how to do it, you probably can't do it.i want sine wave inverter pl z help me 50hz 220 out put 12v input and minimum power factor
