square to sine
trexter711
It was a long time ago when I got the theories.
I need someone to remember me how to change a square to a sine wave using an op-amp.
What about a basic inductor/capacitor tank circuit?
Opamps can be made to simulate inductors at least for wave shapeing. A dual opamp set should be able to convert a square to a sine within the acuracy of the capacitors used.
At a specific frequency though!.
Use the breakpoint method: diodes are used to implement a non-linear transfer function, switching resistors into the feed-back loop. Fisrt, you should convert the square wave into a triangular wave.
The original poster asked how to convert a square wave into a sine, there was no mention about multiple frequencies or bandwidths or modulation methods or anything of that nature, why would I even bother contimplating it if the poster didn't make it a requirement?
But that's frequency dependent and you need a constant amplitude triangle wave for a sine or cosine converter to work.
You could use a microcontroller but it will be limited to low frequencies, it depends on how high you want to go.
The square->triangle is just an integrator and is frequency independent. Keeping it centered and scaled correctly is the fun part though.
My very low distortion sine-wave generator has a variable square-wave frequency, a phase-locked-loop and counter to boost the frequency, a 10-steps sine-rough-shaper then an 8th-order switched capacitor Butterworth lowpass filter. Even without the sine-rough-shaper (it oversamples 10 times) the sine-wave is pretty good.
You could hack into an ICL8038 waveform generator and use its sine-shaper circuit. Its distortion is about 1%. The distortion is audible and can be seen on a 'scope.
