I built the SRF04 unit as shown in the schematic from Devantech. I used a PIC12F508 rather than a 'C' device as my stockist only carries the 'F' version.
I changed the processor statement in the source code to reflect the 'F' device.
I am triggering the module from a 555-based oscillator - transistor inverted to give a 10uS high level, with about 50mS low period.
Scoping around the circuit shows pulses appearing on 7 and 14 of the MAX232, a good transmit signal, a decent amplified received signal, variable width pulses at pin 5 of the PIC (varying as an object is moved back and forth in front of the transducers), but the is nothing out of pin 6 of the PIC.
The negative 10V is being generated correctly.
All this indicate that things are happening as designed, BUT .......
Pin 6 remains at a low level.
The PCB has been checked countless times and is 100% correct.
I do not know what I could have done wrong.
I have tried two PICs - the chances of both being identically faulty would be remote.
Has anyone else tried building their own SRF04 units, and did they work?
Can anyone shed some light on the subject?
