war_isbest2005
Dear All,
I have two stepper motors connected on single shaft for driving a load. Only one motor is powered at a time.I have concerns over backemf generated in the on-powered motor when the other motor is actively driven. This back emf will go to my Un-powered driver and can cause damage. Is there any way to protect my un-powered driver. I figured i will use a dual pole dual through relay and will switch the motor coil to open terminals . Now i have 2 queries
1. What shall i put on the floating terminals of the relay. Shall i short them or connect a resistor across the terminals.
2. There is a scenario in the system when both motors will be off and the load may move because of vibrations/shock. Can i prevent the load from moving if i short the relay under this condition.
