Stepper motor control with PIC16F84A
netbug
I am trying to control a stepper motor with PIC16F84A. The goal is to run the motor for 40 minutes and stop it for 20 minutes. These times must be adjustable using switches. Instead of 40 and 20, you may have 50 minutes on and 10 of, and so on.
I am using L293B to drive the stepper and the stepper is a motor taken from and old HP 690C printer.
Can I step the motor once in a second, or the steps must be smaller ?
Is there any page you might know with a similar project ?
Thank you,
Pedro Cardoso
Yes, but in this case, you should use full step with 2 winding held at a time.
Using switch like this
temp1 = 50
temp2 = 40
if button1, move temp1 to "timertemp"
if button2, move temp2 to "timertemp"
the "timertemp" here is not the real timer of PIC, because you cannot use timer to wait 1mins. But you use timer overflow interrupt and decrement another variable untill it meet 0.
For example, timer1 can wait 65ms at prescaler 1:1. You set a variable to count from 1000/65 down to 0. If it meet 0, reset it to 1000/65 and decrement "timertemp". Until "timertemp" meet 0, reset the timertemp and step the motor. Do this loop forever.
I am trying something similar but my code must have some error, that I am not able to find. As soon as I solve this I'll post again.
Thank you very much for your help
Best regards,
Pedro
I am trying to use a L293 IC to drive an unipolar stepper motor, but it is not working. Does this driver only work with bippolar motors ?
When I connect the stepper motor it runs, for example, 3 steps in one direction and another in the oposite direction. I can't understand what is going on. I verified the connections and even the code, but the motor keeps going forward and backwards ....
Regards,
Pedro Cardoso
Regards,
Pedro Cardoso
This is usually the result of bad wiring, an open winding or bad sequence in signals to the stepper. That's all I can say with the information you're giving.
Hi, thank you all. I tried several ways to solve this problem but I didn't succeed.
Well, I connected 4 diodes (with a resistor of course) to the L293 outputs, so I could monitor the outputs. When I power up the circuit, with the stepper disconnected, the leds flash in sequence but when I connect the stepper, one led is permanently on(actually the 3rd led in the sequence), while other 3 flash normally. This results on a bad functioning of the stepper (2 steps forward and 1 bacwards).
The code seems fine because the leds flash in the right sequence. So I think it must be the motor or the fact I am using a L293 with a unipolar stepper.
I tried every position of the windings, and I think I decteted successfully every windings.
I am trying to solve this problem but I am not able to do it !!!
Any ideas ?
Thanks,
Pedro Cardoso
1) draw out your scheme and post it on to here
2) The L293 does not have the internal diodes to protect the internal transistors. That is you have to put the diodes to your board. But you should use Schooky diodes. You can try with 4001, but you must run at low speed. And I think 4001 is enough. However, why don't u use L293D???
3) Did you connect the right windings to the board? I posted somewhere in here how to know the windings of unipolar steppers.
4) With l293, dual H bridges IC, you make your unipolar stepper run as identically as the bipolar motor. And you have to let the center wire(s) free.
5) In this case, you have to know exactly the right wires of the motor. If you connect wrong wires, the motor will always powered at different endwire of different windings. And because the internal positions of the windings, the motor will not move, and it seem to not pwred (it isn't holding mode but no pwred).
Thank you again for your fast reply. It seems I made an huge error, I connected the centre wire of my stepper to 12 V. I'll try, as you said, to let this cable free.
I am using a L293B with 20 pins. This quite strange because the datasheet of this component tells that the L293 B only has 16 pins, the one with 20 pins is L293 E, so I don't know if my circuit has the diodes integrated. Anyway, I'll connect the diodes (1N4001) to the circuit, then I'll reconnect the stepper and finally I will tell you if it works.
Thank you,
Pedro Cardoso
I disconnected the common wire and it worked !!! However, I need once more your help. Please take a look at my code. I wanted to keep te stepper running for 5 seconds and stopped for another 5 seconds, but instead of this, the stepper runs forever.
Thank you again
Pedro
PROCESSOR 16F84A
RADIX DEC
INCLUDE "P16F84A.INC"
ERRORLEVEL -302
__CONFIG 0x3FF1
ORG 0x0C
count1 RES 1
counta RES 1
countb RES 1
countc RES 1
time_off RES 1
seconds RES 1
LED Equ PORTB ;set constant LEDPORT = 'PORTB'
ORG 0x00
BSF STATUS, RP0
MOVLW B'00011111'
MOVWF TRISA & 7FH
MOVLW B'11110000'
MOVWF TRISB & 7FH
MOVLW B'00000100'
MOVWF OPTION_REG & 0x7F
BCF STATUS, RP0
;***** Main code ******
Loop1
movlw d'5'
; time in seconds
movfw seconds
Loop3
movlw b'00000001'
movwf LED
call Delay ;Delay of 250 ms
movlw b'00000010'
movwf LED
movlw b'00000100'
movwf LED
movlw b'00001000'
movwf LED
decfsz seconds,1
goto Loop3 ; Ciclo interior
movlw d'5'
movwf time_off
movlw b'0000000'
movwf LED
Loop4
; 1 second delay
decfsz time_off,f
goto Loop4 ; Ciclo interior
goto Loop1
; ******* END Main code *******
;250 ms delay
Delay movlw d'250' ;delay 250 ms (4 MHz clock)
movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta,f
goto $+2
decfsz countb,f
goto Delay_0
decfsz count1,f
goto d1
retlw 0x00
end
Thank you for your correction. I made a big mistake .... Well I will try to put everything to work.
Regards,
Pedro
The stepper is working fine, but when I connect a dip switch block to RA0...RA3, the PIC freezes. If I remove these connections it works again !!! My software is the one I posted above. I configured TRISA as intputs and TRISB as outputs.
Pedro
Pedro
Well you don't seem to be accessing PortA at all in the software above, but I'm confused by the way you appear to be declaring your variables?.
ORG 0x0C
count1 RES 1
counta RES 1
countb RES 1
countc RES 1
time_off RES 1
seconds RES 1
ORG (as far as I'm aware) sets an address in program memory, not in data registers.
Try this instead:
cblock 0x0C
    count1
    counta
    countb
    countc
    time_off
    seconds
endc
However, I've assembled your code, and it seems to assemble correctly.
Are you sure you're not shorting something out with your switch?.
Hi everybody,
Thanks to all of you my stepper is working fine !!! :D
I need some more help on this project.
I can divide this project in two:
1- Stepper motor control
2- LCD control
So I need some help on point 2. What I want to do is to control several motors at the same time and with diferent speeds. So each motor will have separate control.
The problem is I want to display on LCD the following information:
- Running time of a specific motor
- Speed of that motor
- Actual time
So with only one LCD, I would like to see the running time of each motor. I expect doing this with a press button that allows me to choose the motor which running time I want to display.
I need some help to find the better solution from the hardware point of view. Should I make the clock with the PIC ?? If I need to count the running time of 4 motors, do I need 4 clocks and then 4 PIC's ? Is there a simpler way to do this ?
Best regards,
Pedro Cardoso
Take a look to Nigel LCD tutorial, you will find many helpful codes.
To control multi stepper, you need a decoder like 74LS85? Each time you output, you use 4 MSb to send the address of your motor, and use 4 LSb to send the control signal. You can see it so clearly in Douglas W. Jones tutorial, the final chapter (as I remember, it's chapter 6 in old version).
You can search his name on google and get the tutorial for free.
He used 74LS194 as a shift register, and LS85 to decode.
For time control, you don't have to display to see how it work. You can use IDE to debug and see it in registers view.
For LCD, Nigel's tutorial will help.
But this way all motors will run identically, don't they ?
I want to control several motors completely idependent one from another. The first motor can start running now, at 100 rpm CW. The second motor starts running 20 minutes later at 200 rpm CCW. You see, I have two motors running in oposite directions and diferent speeds, so we should use one pic for each motor, don't you think so?
From the software point of view, how can I do this control with the same PIC ?
Regards,
Pedro Cardoso
Using a seperate PIC for each motor would probably be easier to do, and more versatile. It would be quite easy to program a PIC to accept simple serial commands and control a stepper motor accordingly - the low price of PIC's makes it a fairly cost effective option.
To do it with one PIC would also be easily possible, simply generate interrupts with a timer at a rate as fast (or faster) than your highest stepping rate, in your case every 0.3 seconds (for 200RPM). Step the fastest motor every interrupt and the slower motor every second interrupt.
You could obviously do this at a higher rate, say every 0.03 seconds, and step one motor every 10 interrupts, and the other every 20.
Which method to use really depends on the application, if the motors are far apart it's probably easier to use seperate PIC's (so you don't need to run as many wires). If they are close together it doesn't really matter which way you go.
My preference though would be seperate PIC's, design yourself a generic stepper driver design that accepts a serial input - you can then use it over and over again, fed from almost anything!.
