Stepper !!!
watzmann
Hi All ,
i have an idea and really like to do it ,
i have agood combination of stepepr motors , and i can use them well with microcontrollers ,
my idea is i need to send any drawing from AutoCAD to the microcontroller and then using a the 3 Axis mechainsm i can draw this one using this three stepper motors ,
the same idea of CNC router machine , as for the mecahism i have no problem with it , my problem is how to this connection between Autocad and the microcontroler
You know how when you install some new hardware, there is a disk included... and you have to install a 'DRIVER'. Or when you downgrade your system with a 'new' version of Windowz, and you can't get your scanner, printer, or most anything else to work, because you need to spend half a day searching the internet for updated drivers...
You'll need to write a custom driver, for your custom hardware. Not sure this is very common. Maybe something on CNCZone.com... But if it's Windows. it can't be easy...
Export the files as a gerber or similar text readable file, write a visual basic front end which takes the co-ordinates and translates them into paths/pen up and downs then uses the parallel port to output pulses to the stepper motor drivers.
