some months ago i posted a question about the stepping motor m49sp-1
https://www.electro-tech-online.com/threads/mitsumi-m49sp-1.42416/
from what i could figure out from the connectors the motor is a bipolar in spite the fact that the data sheet says it is unipolar because i can't find a fifth connector that unipolar motors have. after searching the net i found the following circuits
i went for the bipolar circuit and after i made the connections when i started the circuit the motor goes one step forward and one step backwards. my questions are
1. am i using the right circuit? if not at the unipolar circuit how should i make the connections? from the output of the ic3 (at the unipolar circuit) to pin 1 of the motor and from the pin 2 of the motor to 12v dc? (the same thing goes for the other 2 pins of the motor)
2. in this case the C and D phases of the circuit are ok to leave them empty?
