blueroomelectronics said:The 18F have a table read command that would be handy for reading a large table right out of Flash memory. You could write a fancy 16F program that sorts out using large tables when using "retlw" else you'll need an external EEPROM.
Pommie said:Many of the newer 16F series have read and write to flash which is very similar to the table read command on the 18F. I think the problem with the 16 series would be lack of available flash.
blueroomelectronics said:Also the 18F can store two bytes per word, the 16F one byte per 14bits unless you're writing some pretty fancy software.
