I made a board with an 18F2550 driving a standard 2*16 line LCD module and using the USB interface to get data from a PC to display. It hardly seems worth posting the circuit, it's just directly connectly to the USB port and the LCD on the appropriate pins. It's powered from the USB and has a 0.47uF capactitor on the VUSB line. And a 20MHZ crystal and 2 22pF capacitors for the clock.
I have one LCD module which it works fine with.
I have a second different LCD module (different colour, very different board layout) which is working find as a display but when it's plugged in stops the USB from working properly. The PC recognises there is a device attached but fails to enumerate it.
I'm just wondering if anyone has any idea what could be wrong as it seems a very strange fault.
EDIT: More information - The USB bootloader on the board works with the LCD plugged in. It's only when this particuar display is actually used that it stops the USB from working properly, even though it seems to display the requested text perfectly well
