hi, this will probably turn out to be a stupid error by me but can anyone tell me why i get the following happen.
i am doing some transistor switching stuff and wanted to scope the line's,
the power supply in this case is a old ATX one from a computer, i disconnected my circuit and decided to see how lumpy the 12V and 5V lines on the ATX are as its old. first i measured with a good quality DMM and 12V line reads 11.889V (i figure thats ok) the 5V line reads 4.87V, now as there isnt a load on the supply i figured that was all pretty good. So i then measured using my cheaper not so good DMM and the measurements were pretty close! (well happy with that). Now come the odd bit
i tried scoping the lines i set probe to x1 and set scope to x1 i connected ground lead to calibration ground and probe tip to calibration tab (1V 1kH) and get a nice square wave at correct frequency and voltage.
i then attach probe ground to ATX ground and scope Tip to 12V and press auto set up. i get a amplitude reading of 63mV!! i have tried manualy setting the scope and get the same thing i have also tried another scope and get same reading, so what am i doing wrong???? why are the scopes reading wrong voltage and the DMM are correct??
Logan (frustrated)
Logan (frustrated)
