Menticol
Active Member
Hello again!!
I have bought yesterday a stereo amplifier kit, that uses TDA7262. I'll make a schematic for that PCB, but I think is a copy of the suggested application found in the datasheet
Even when I didn't posted the schematic yet, I guess the fail symptoms are very recognizable for an expert:
____________________________
Either when feeding the circuit with 12V battery or PC PSU:
- Very loud hum and interfence when the input (a 3.5 mm plug) is not connected to anything, or if touched with the bare fingers
In the following cases, the PC PSU +12V and 0V rails are used to feed the cicuit:
- Loud ground loop when connected to a PC sound card. Grounding the circuit with the soundcard ground doesn't fix the problem
- When feed with signal coming from an iPod or external player, the circuit works perfectly
Thank you in advance!
