my sub woofer is making disturbing noise along with two front speakers but when i remove the subwoofer connection from the circuit board then the front speaker aren't making disturbing sound and working correctly ,
recently i changed the two capacitors in the amplifier circuit board, 3300uf 25v capacitors, what may be the problem in circuit board, my circuit board has mainly 3 TDA2030A transistors with heat sink ,2 capacitors 3300uf 25v , four 5392 diodes and many more resistance and small capacitors.
where may be the problem ,which part need to be replaced..or how to solve the problem
@i replaced that two capacitors coz they got leaked.(2 months ago)and this problem is arising from last few days
@the replaced capacitors are fitted in right polarity
@the disturbing noise means distortion noise like when you play speakers on higher voltage and after that speakers are making that type noise.
@but i checked my speakers and woofer in other system they are working fine without noise there
@that is not burnt sign there , it is sign of some kind of paste
thanks
thanks
