Subs and functions in C
be80be
Been playing with C for awhile. Its a little bit of a change any way. Whats the right way to write a Sub in C
Nice thanks I was thinking more like this C uses functions as both unlike my beloved Basic.
void send_data(unsigned char data_out)
unsigned char i;
i=8;
while (i)
data_out = data_out >>1;
i--;
SClock =~ SClock;
There is no 'right' way, it's just the ways that work efficiently.
A basic sub is just a function that doesn't return anything. So your void send_data(unsigned char data_out) is equivalent to a sub.
Well I been playing with MikroC and read dang near there whole help file and couldn't fine a thing to point me right. But i think I'm on the right track now
I wrote that piece and complied it and it said that main was a empty sub. Lol it was . Thanks Mike And Sceadwian
Now all i need is to figure how to do a bound In C
Like Send out 0b10101010 out A GPIO.B0 one bit at a time
int i;
 i=8;
  while (i)
    GPIO.B0 = data>>1;
      i--;
       SClock=~SClock;
A for loop will do that for you,
    for(i=0;i<8;i++){           //for 0 to 7
        GPIO.B0 = data&1;       //send out bit zero
        data>>=1;               //shift data right 1 bit
        SClock=~SClock;         //doesn't this need to be 1 then 0
Edit, what do you mean by Bound?
Bound just lets you set it to what your sending so you don't have to set 0 to7 it would 0 bound to Data and it's size. Thanks Mike I feel like a real dummy I should of thought about a for loop.
I for loop would work great seeing I can't send more then 8 bits at a time. Thanks agin Mike.
Dang the joy of a New compiler reserve words I new i wasn't that dumb data is a reserve word. My code worked Mikes code works and now it back to doing something useful. I'll post the whole thing when I get done it's a two wire LCD.
Yep I got the idea i could use data as a variable from your site MrRB.I it worked before but I'm using the 4.80 beta. Funny how simple things seem to get me LOL
I slapped this baby in a nice do loop so it would row along and so far so good
#define  SClock GPIO.B1
unsigned char Sdata;
unsigned char i;
void main() {
OSCCON = 0x72;
TRISIO = 0b00000000;
CMCON0 = 7;   // no comparator
ANSEL = 0x00;
  do {
       Sdata =0b01010001;
        SClock=0;
        GPIO.B0 = Sdata&1;       //send out bit zero
        Sdata>>=1;               //shift data right 1 bit
        asm nop;
        SClock=1;         //doesn't this need to be 1 then 0
    } while (1);
It shifts out nice
Whoops! Thanks for the heads up! I will edit that page and change the variable name "data" to "sdata" or something that will work with the new compiler. :)
