davepusey
I have a set of 4-channel net lights. Each channel has it's own fuse bulb. Unfortunatly i am running low on fuse bulbs and CANNOT get any spares AT ALL. :cry:
I am going to have to use normal bulbs to replace them instead. I have already build a dimmer pack for the lights and was wondering if it would be possible to use normal fuses (20x5mm type) as a substitute for the fuse bulbs. These would be added to the outputs of the dimmer pack. If so, would this be just as safe and what value fuses would i need to use?
If you need furthur explanation, i can post a diagram.
