Hello,
and would be inconvenienced if the wires explode/melt away.
-Thanks
I wonder how he plans to test it?
Ermmm I aint volunteering as his patient....![]()
Do you know the estimated discharge time? A joule is one watt second. If you dump it all in one second that the same as a 14.4 mega watt load at 1600 volts or about 9000 amps for one second.
Two 4/0 welding cables can take that kind of burst. they can hold a continuous duty 1000 amp submerged arc welder without trouble. Even with 20 KA peaks I doubt you would bother them one bit.
Why would you want to build a defibrillator anyway?
