How do you setup switches on a PCB that work from outside a case?
I am using the switches that mount to the PCB. I would like to activate them from outside the case. Indoor use, small is good.
Is there a right/easy way to do this or will it work to drill a hole and stuff a matching plastic rod into it, maybe a rod in a tube epoxied to the case. Mushroom the underside of the rod to keep it from falling out. The space between the case and the top of the switch will be 2 or 3 mm. I have some adjustment here. Maybe someone make an button insert that pops into a hole to push the button?
The case is a Hamond with a wall thickness of 2mm.
The switches are E-Series Tactial Switch 6.4X5.0MM 130G switches.
Mouser 612-TL1107BF130W DataSheet
