1. Name both nodes that the cap connects to (unless one is GND) by clicking on the "A in a box" icon on the toolbar and typing in a name. Attach the name to the node.williB said:is there any way to give a cap an initial voltage??
I should have clarified that. Yeah, just name the node that isn't grounded. GND is defined as node 0, and is zero volts by definition. You can't set an initial condition on GND.williB said:and if one node is ground?
same procedure?
Under what conditions? Can you post a schematic? When I place a 10 farad cap in parallel with an ideal (zero resistance) battery, the initial voltage on the cap is the battery voltage. Spice does that automatically.williB said:Having an initial voltage on a very large cap is essential when it is in parallel with with a battery..
because the battery just drains into the cap otherwise..
That makes sense.williB said:ok lemmy wait till the sim is done ..
but i've got or i had a 1.2V battery series resistance = 0.08 ohms. in parallel with a 100 Farad cap series resistance = 0.003 ohms , and when i started the sim ( without initial conditions) the battery voltage went down , not up..
