Symbol not previously defined (Send)
ttbuddy
Hi to all the prof. here...
I am adding a serial send routine to my existing code in PIC assembly.
I am using PIC 16F88 with MPLAB version 8.10.00.00
However when i compile my file, i get this error:
Warning[207] D:\WATT METER (DESIRED DESIGN)\WATTMETER.ASM 1480 : Found label after column 1. (settle)
[B][COLOR="Red"]Error[113]   D:\WATT METER (DESIRED DESIGN)\WATTMETER.ASM 1488 : Symbol not previously defined (Send)
Error[113]   D:\WATT METER (DESIRED DESIGN)\WATTMETER.ASM 1490 : Symbol not previously defined (Send)[/COLOR][/B]
The post below is the file I am implementing. Red highlighted part is the one i added for send serial routine. Thanks. I wonder what silly mistakes i had done.
  • watt.txt
store_Ah:
	mov16	dd+2,AmpHours
[B][COLOR="Red"]call 	Serial_sent[/COLOR][/B]
Serial_sent:
   banksel      SPBRG
   movlw      .25                  ; 9.6kbps
   movwf      SPBRG
   movlw      b'00100100'      ; brgh = high (2)
   movwf      TXSTA            ; enable Async Transmission, set brgh
   ; Provide a settling time for startup
   banksel      tmp1
   clrf       tmp1
   settle
   decfsz       tmp1, f
   goto       settle
   ; Send a character through the UART
loop
   movf AmpHours, w
   [B][COLOR="Red"]call Send[/COLOR][/B]   ;error here
   movf AmpHours+1, w
   [COLOR="Red"][B]call Send[/B][/COLOR]   ;error here
   goto      $
; SEND function
send
   banksel      TXREG
   movwf       TXREG            ; Send data which has been stored in W
trans_wt
   banksel      TXSTA
   btfss       TXSTA, TRMT         ; Loop until data is sent
   goto      trans_wt
   return
If you ask, MPLAB can be case sensitive, just change your label send to Send, and the problem should disappear.
Like this?
The problem still exists:
call 	Serial_Sent
Serial_Sent:
   banksel      SPBRG
   movlw      .25                  ; 9.6kbps
   movwf      SPBRG
   banksel      tmp1
   clrf       tmp1
   settle
   decfsz       tmp1, f
   goto       settle
loop
   movf AmpHours, w
   call Send
   movf AmpHours+1, w
   call Send
   goto      $
loop
   movf AmpHours, w
   call Send   ;error here
   movf AmpHours+1, w
   goto      $
; SEND function
[B][U][size=+1][color=red]S[/color][/size][/U][/B]end
   banksel      TXREG
