Bioelectronics
Hi Folks!
I would like to make a syncrometer.
http://www.syncrometer.com/build/
I am new to electronics so please try to give me answers that will be appropriate to beginners.
I am trying to make the test surface.
The instructions says
Cut two 3 1/2 inch squares out of stiff paper such as a cereal box. Cover them with slightly larger squares of aluminum foil, smoothed evenly and tucked snugly under the edges. You have just made yourself a set of open capacitors
If you look in the picture there is a screw in the centre of the plate and how come they don't write about it in the instructions
http://www.energetic-medicine.net/Syncrometer.html
If you look at this one the plate does not look like a foil paper and it looks like a sturdy piece of aluminum
Also the wires going from the switch to the plate.
Can someone tell me how the wires are connected from the switch to the screws
Thank You Very Much
Thank You Very Much
