yusuf
Hello friends :
I was using three separate sensor circuit to sense water , empty & full tank condition...
It also takes place and it's too bulky..
So I used the unused gates from old sensor circuit..
You can see my old sensor circuit in my attachment...
I have used the unused gates of my old sensor circuit to sense water & full tank condition..
I have made this new circuit which you can see in my attachment...
But the problem is ....
I have attached the problem report with the test I have done in my attachment...
If I touch common sensor wire + empty sensor wire = the empty led glows..
Or If I touch common sensor wire + water sensor wire = the water led glows
or If I touch common sensor wire + full sensor wire = full led glows..
But by :
touching common sensor wire + empty sensor wire + full sensor wire = all led turns off..
or by touching common sensor wire + empty sensor wire + water sensor wire = all led turn off
If I add the 3rd sensor wire all led switched off...
It work when I use on two sensors wire..
But I want :
By touching common sensor wire + empty sensor wire + full sensor wire = empty & full sensor led glow.
or by touching common sensor wire + empty sensor wire + water sensor wire = empty & water sensor led glow..
Please have a look on my both attachment and kindly help !!
Thanks in advance..
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But by :
But I want :
Thanks in advance..
