rahulrahullll
------------i made the tda 2050 amplifier played for 30 min-in-low volume----suddenly volume became very
high crackling noise comes out along with song---so switched it off---then checked transformer and tda
2050 ic attached to a big heatsink--slighty warm---then checked power supply everything ok---
then again tried to play song----no sound --but speaker vibrating tremendously as it would burst out
making a booming sound----checked amplifier with another speaker same thing----
------MAIN ISSUE-------------
---i was using mobile phone and pc 3.5 mm jack output (inbuilt realtek soundcard in motherboard) as
signal source----after amplifier went wrong---
i used stereo headphones to check signal output of mobile and pc-----sound was coming out-------
---------BUT ONLY MUSIC AND HIGH FREQUENCY sound coming--VOICES IN THE SONG ARE ALMOST GONE JUST ECHOING
SLIGHTLY------------SO THE AMPLIFIER DAMAGED MY PC AND MOBILE PHONE 3.5 MM SOUND OUTPUT-------
-----![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
--------------------MY QUERY IS------![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
1----------IS THERE ANYTHING LIKE SIGNAL INPUT SECURITY IN TDA 2050 AMPLIFIER WHICH IN FUTURE WOULD KEEP
MY SIGNAL SOURCE DEVICES PROTECTED IN FUTURE ?
2----------MY BEST GUESS IS AMPLIFIER FAILED AND SEND POWER DIRECTLY TO SPEAKER AND SOURCE SIGNAL
DEVICES AS PC AND MOBILE so they are damaged------CAN ANYBODY TELL ME WHAT EXACTLY HAPPENED ?
------------------DETAILS OF TDA 2050 BUILD---------------
i made dual rail tda 2050 circuit---according to this----
https://diyaudioprojects.com/Chip/DIY-TDA2050-Hi-Fi-Chip-Amplifier/
pcb diagram----http://diyaudioprojects.com/Chip/DIY-TDA2050-Hi-Fi-Chip-Amplifier/TDA2050-ChipAmp-PCB-
Component-Layout.pdf
parts list----http://diyaudioprojects.com/Chip/DIY-TDA2050-Hi-Fi-Chip-Amplifier/Updated-List-of-
Components-for-PCB.pdf
---------power supply--transformer dual rail---16-0-16 v ac------
22.5-0-22.5 v dc after bridge rectification 10 a and filter capacitor 2200 uf 50 v--------
power circuit looks similiar to this type-values are different--i have used--bridge rectification 10 a-
-------------------thank you---------------------
