gaspode42
Hi
I am looking for some advice for my first amp. project.
I want to build a micro controlled audio circuit that contains an amplifier and am looking at something like the TDA7266 (TDA7266 7 W + 7 W dual bridge amplifier - STMicroelectronics).
I want to use a digital volume control on the system so I am looking at putting something like this https://www.ti.com/lit/ds/symlink/pga2311.pdf on the amplifier input.
The question I have is that the datasheet for the TDA7266 states that the open loop gain for the chip is 26dB. The output of the circuit feeding the amp is giving 2V RMS centered around ground. If my math is correct that would result in an output of 56V P-P (10^26/20*2/sqrt(2))???? So I would need some sort of additional attenuation on the input.
What is the best way to achieve this? Could I use an additional PGA2311 or is there a better way. Do I also need to provide a bias to the input signal to center it around something other than ground?
Any comments would be much appreciated as although I am fine in the 'digital domain' analog is out of my comfort zone. I will post my finished project with all schematics and code when the project is complete.
Thanks in advance for your help and support.
