Hi all,
No doubt some of you will have been following the saga of my PIC-driven clock project. Today it has taken a weird turn as the crystal circuitry has started to misbehave.
The schematic:
(|>o = NOT gate = 1/6 of a 4069)
Here's the puzzle. My circuit is powered by a 4.5V battery supply which is enough to power the PIC/display but doesn't seem to get the crystal ticking. I previously powered the 4069 with 9V, so I tried that and it works. It also continues to work if, after starting off at 9V you take the wire out and connect it to the 4.5V supply.
If you reverse that (start with the 4.5V batteries then connect it to the 9V supply) the crystal does NOT work.
So,
1) Why this weird one-way phenomenon? I checked after disconnecting the 4.5V supply and the voltage was at zero everywhere, so I don't think there was any charge left in the capacitors or anything (they're tiny anyway).
2) Is there some simple fix e.g. reducing the values on the resistors so that it works at 4.5V?
3) I also have a 2MHz crystal - do I need to make any changes to the above circuit to get this working. (not so urgent)
Thanks,
ahydra
The schematic:
|-<32768>-----|
--[10M]-[220k]--> out Legend: <32768> = crystal, [ ] = resistor, ( ) = capacitor
| | | All junctions are connections
--|>o--| |
(33) (33)
0V 0V
Thanks,
ahydra
