Dear Friends,
Please help me to do following job.
It is required to develop a temperature-monitoring device, which is able to monitor the temperature of an oven. The device must be able to deactivate the heating coil when temperature exceeds 80 degrees and reactive the heating coil when temperature drops below 45 degrees. The heating period of the oven is 2 minutes upon-up. After 2 minutes, the heater will be deactivated.
This circuit should demonstrate the usage of ADC (Analog to Digital Conversion) of the 68HC11E9 MCU in monitoring and moderating the temperature of the oven. This should also use the time delay routines.
thanx a lot
thanx a lot
