the compltete description of the project is as follows
Temperature Control System
Objective: To implement a control mechanism that regulates the temperature of water contained in a vessel.
we have to use temperature sensors which will detect any change in the temperature of the water if the temperature is higher than the desired value it should cool down the water with some variable resistor and the power source of the project will be the dc source also the temperature we r maintaining is 25 centigrade
...Temperature Control System
... if the temperature is higher than the desired value it should ...maintaining is 25 centigrade
thanx 4 replying
ericgibbs
yesi can have the comparator and the thermistor here
and the refigeration thng not to be implemented the design have in mind that i have a high power dissipation resistor placed in the water and if the temperature of the water rises then the resistor col down and this could be done with varying the current inversely with the temperature the word cool down by resistor meant that let the liquid cool down on its own i mean not heat the liquid anymore tell me if my thinking is correct and help me out with this
regards
