PhillDubya
I am currently helping design a circuit that would alter voltage linearly to changes in temperature.
Temp goes up, and red light gets brighter due to linear increase in voltage; while blue light intensity goes down, due to a inversely linear decrease in voltage with temperature.
The opposite would be true when temps get cooler. I.E., the blue light gets brighter as the temps go down, and the red light gets dimmer.
What I am considering is using PWM from a 555, and sending that output to an array of 3904npn transistors which will input to a ULN2803 Darlington array to drive the led's.
One 555, plus one 3904 array, plus one ULN2803 per LED set. This would be set -up for increase in temps from a diode.
Another one just the same, except set up for a decrease in temps.
I know a uprocessor using an ADC + PWM clock might be a solution, however, that is off the table due to the complexity, as the person I am helping has no experinece with it what so ever.
Any ideas for improvement, especially for an easier, if possible, solution.
Your inputs are appreciated.
Edit: to be clear, there will be a lot of LED's thus the reason for a driver, and why I am not running them directly from the 555.
Probably 20 LED's per color, so roughly worse case, 400mA consumption.
