Estroncium
Hello people , I’m new here and a friend told me that maybe I was able to get help here.
I’m running a test on fuel delivery on a series of diesel fuel pumps, using a calibration test bench with, the problem is , that the way the volume is recorded is via a calibrated test tube , and you are to obtain the result of each injector visually , for the purpose of my project visual readings are not that accurate (varies depending on visual angle ) and takes lots of time . I also need to keep records of all testing results and conditions.
I was thinking of a flow sensor , but they are to expensive and the biggest total flow is 50 cc , a friend subjected a rage finder but the tube is inch 12 inches long and there are 18 of them.
if it s at all posible i will like it to be displyed and recorded on a pc
Any ideas?
Any ideas?
