Testing an Industrial AC and DC Variable Speed Drives
NiCeBoY
Hi all,
i did this test in the lab. can anyone help me with some doubts that i have?
below is how the system was setup.
Power circuit of lab drive setup
The shafts of motors M1 and M2 are coupled directly. The AC VSD (A1) is a two-quadrant drive, and hence cannot provide braking. Motor M1, therefore, operates always in the motoring mode. The DC VSD of motor M2 can provide operation in four quadrants. It is set for torque control (Fig. 2). If the set torque of the DC drive is of the opposite direction to the direction of rotation selected on the AC drive, the DC
drive will operate in the braking mode. Consequently, M1 operates as a motor, and M2 – as a generator.
**broken link removed** fig2
Torque/Speed Characteristics of AC Drive
1. On the control panel of AC drive, select a frequency in the range of 15 Hz – 20 Hz. This is the parameter of the first characteristic to be taken. The selected direction of rotation is clockwise (positive).
2. Start the AC motor by depressing the START pushbutton.
3. On the control panel of DC drive, switch to local control (LOC) by depressing the LOC/REM pushbutton.
4. Start the DC drive by depressing the START p/b.
5. On the DC drive control panel, set the reference torque at a negative value corresponding to the braking of the AC motor. The torque is displayed as a percentage of the motor nominal value, and can be varied in the range of 0 to (-80%).
6. In the table below, record the displayed values of frequency f (AC drive control panel), torque T and speed n (DC drive control panel).
7. Record the drive speed for at least four other frequency values, selected to cover evenly the remaining range up to 60 Hz. The torque is maintained constant by the torque controller of the DC drive.
8. Repeat steps 5, 6 and 7 for at least four other torque values, selected to obtain measurement points spread evenly in the range of 0 to (- 80 %). The set of frequency values at which the speed is measured remains the same for each torque value.
**broken link removed** tab1
Torque/Speed Characteristics of a DC Generator
1. The procedure is similar to that described in the previous section, except that the parameter is the dc machine terminal voltage Vt, displayed on the control panel of the DC drive. The frequency is adjusted to obtain the required Vt at a given value of T.
2. Select at least four values of Vt spread evenly over the range of 0 – 380 V. These are the parameter values for which a family of characteristics will be taken.
3. With the AC drive on, set the torque at a value within the available range of 0 to (-80%). Adjust the AC drive frequency until the selected value of Vt is obtained. For each value of Vt, record the displayed speed n.
4. Repeat step 3 for at least three other values of T, making sure that all torque values are spread evenly over the full range of 0 to (- 80 %).
**broken link removed** tab2
Output Voltage and Current Waveforms of a PWM VSD.
1. On the oscilloscope, monitor the phase current and the phase voltage of the induction motor. Keep the motor loaded with a torque of at least (-50%) (as displayed on the DC drive).
2. Sketch the waveforms for three widely spaced frequencies in the range of 25 – 60 Hz. Note the differences between the voltage waveforms. Note that, in your report, you are required to include the scale of the presented graphs.
3. Measure the amplitude of pulses in the voltage waveforms.
4. Note the response of the phase current to the voltage pulses.
30hz
40hz
50Hz
Anyone can tell my why the current waveforms are of the shape shown above and why the amplitude of the pulses in the output voltage is constant and how the output voltage magnitude is varied?
