The question...To buffer or not?
eTech
Most Helpful Member
I have a circuit that contains panel mounted pushbuttons, PB1-3.
See attached.
U101A,B is a 74HCT174 Dual D Flip Flop. NOR's are 74HCT02.
There is about 5-10 inches of wire from each leg of each pushbutton
to the circuits on each PCB (2 PCBs').
The question:
Should I use a hex buffer as shown (dashed symbol) to buffer the signal? 74HCT07?
Or maybe I actually need additional buffers to each PB?
Suggestions?
thanks
I wouldn't have thought a buffer was necessary. I would be more concerned with overcoming switch bounce.
Hi Alec...
Do you think the debouncing shown in the circuit is adequate?
I was thinkin maybe adding buffers might help with debouncing,
but I wasn't sure if I needed more debouncing..
Switch bounce may result in a train of pulses lasting several millisecs in total. I don't see anything in your circuit with a time constant long enough to cover that. I see 1k/.01n combos on the IC inputs, but the time constant there is only 10 microsecs. Also, slugging the clock input of the latches like that may be a problem as the latches need rapidly rising and falling clock edges.
Using a Schmitt trigger buffer, such as the CD4584, with an input RC time-constant of at least 50ms, should provide a good debounce function while still having a fast rise-time output.
Those caps ar 10nF not .01nF
I would put a small value resitor in line with PB3 to protect the output of IC101a(?) E
My bad. Should have typed .01u.
You can connect the '174 as per the attached to provide debounce.
Hi canad...
So the debounce looks ok as is right? Except for adding a
small resistor, say... 1K ohm?
How does your circuit help debounce?
When the button is pressed the clock input of the latch goes high/low/high/low/.....umpteen times because of contact-bounce. The first high toggles the latch. If we assume D was, say, low at the time then Q goes low and not-Q goes high. Because of R2/C1, D takes about 50mS to change from low to high. During that 50mS any further clock pulses will all try to set Q low, i.e. they can't flip the Q state rapidly low/high/low/high.... Interestingly, Crutschow also refers to a 50mS time-constant for debouncing.
