Thermo switch to control fan...
jdepaul
Hi -
Question about a thermo-switch to control a simple fan. Is there an adjustable thermo switch that can be set to turn on a fan when the temperature reaches, say - 90 degrees F?
The application would be a car battery powered fan (inside the vehicle) that would kick on when the car temp reached a preset threshold.
Hi -
You can buy a range of normally open or closed 'fixed ' temperature switches.
EDIT
: look here for examples
https://cpc.farnell.com/jsp/search/...switches&Ntx=&isGoback=false&isRedirect=false
Alternatives...
These look pretty fancy (and some require shipment from Europe... :) - could the same be achieved by employing a house thermostat - like an inexpensive programmable thermostat to control the on/off power to the fan?!
THanks in advance -
Yes, but your wife will be really mad when she goes to turn on the A/C, and the thermostat is missing!
They're not fancy, they're basic bimetallic strip thermostats, no fancy programmable microcontroller, just connect in series with the fan and it'll work.
THanks in advance -
Yes, you can.
In fact the Google search I did found loads of them. I deliberately avoided them because I thought you wanted something more simple and robust.
